Introducción
Using the chuck key, you'll be able to remove stuck drill bits that you couldn't free with your bare hands.
Herramientas
Partes
No se requieren partes.
Locate one of the indents in the side of the chuck. Line up the chuck key with this hole and the teeth right below it. Locate one of the indents in the side of the chuck. Line up the chuck key with this hole and the teeth right below it.
  • Locate one of the indents in the side of the chuck. Line up the chuck key with this hole and the teeth right below it.
Agregar Comentario
Turn the chuck key counter-clockwise.
  • Turn the chuck key counter-clockwise.
Agregar Comentario
Pull the drill bit free as the jaws loosen.
  • Pull the drill bit free as the jaws loosen.
Agregar Comentario
Conclusión
Matt
Miembro Desde 10/10/10
365 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 5-17, Maness Fall 2010 Miembro de Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 35
Todo El Tiempo: 3,222
