Introducción
Taking out the thumbwheel.
Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
  • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
  • Gently pry open button and remove button.
  • Do this for each of the 3 buttons remaining.
Agregar Comentario
The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
Agregar Comentario
Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  • Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
Agregar Comentario
Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
  • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
  • Use the Torx 6 screwdriver to remove these 2 screws.
  • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
Agregar Comentario
After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
  • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
  • You can use your hands to simply pull apart the top casing from the bottom casing.
Agregar Comentario
Remove 2 screws using the Torx 6 screwdriver.
  • Remove 2 screws using the Torx 6 screwdriver.
Agregar Comentario
The thumbwheel and casing will be loose, gently remove it.
  • The thumbwheel and casing will be loose, gently remove it.
Agregar Comentario
Linea de Meta
michael albaum
Miembro Desde 20/01/10
45 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 3-19, Maness Winter 2010 Miembro de Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 2,038
