Saltar al contenido principal
Sidekick II Keyboard Replacement
Qué necesitas
  1. Sidekick II Keyboard Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Keyboard Replacement: paso 2, imagen 1 de 2 Sidekick II Keyboard Replacement: paso 2, imagen 2 de 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Keyboard Replacement: paso 3, imagen 1 de 1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Keyboard Replacement: paso 4, imagen 1 de 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Keyboard Replacement: paso 5, imagen 1 de 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II Keyboard Replacement, Keyboard: paso 6, imagen 1 de 2 Sidekick II Keyboard Replacement, Keyboard: paso 6, imagen 2 de 2
    • Remove screen from case
  7. Sidekick II Keyboard Replacement: paso 7, imagen 1 de 1
    • Remove both black "rivets" from the back of the case with the plastic opening tool.
  8. Sidekick II Keyboard Replacement: paso 8, imagen 1 de 1
    • Push keyboard out of the front of the casing with your thumbs.
    • Make sure not to press too hard; you may break the board.
Linea de Meta
michael albaum
Miembro Desde 01/20/10
87 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-19, Maness Winter 2010 Miembro de Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,947
