Introducción
The XLR connector is the point where the XLR cable is inserted into the microphone. The XLR cable then carries the sound to the amplifiers.
Partes
No se requieren partes.
Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
  • Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
  • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
Agregar Comentario
With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
  • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
  • Do not push the microphone past this point or the connector may become stuck.
Agregar Comentario
Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
  • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
Agregar Comentario
Conclusión
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
3 personas más completaron esta guía.
Ronald Lam
Miembro Desde 27/09/12
211 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-53, Forte Fall 2012 Miembro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Miembros
18 Guías creadas
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Joe Lee - Contestar
Hi. I followed up to step #3. However, the connector does not stay tight. It keeps on moving inside with a little push.
Joe Lee - Contestar
Hi. I followed up to step #3. But, the connect is still loose… Moves inside the microphone.
Joe Lee - Contestar
Are the threads on your screw stripped?
Daniel Berger - Contestar
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - Contestar
I would take your microphone into your local ACE and see if they can help you find the right size
Daniel Berger -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 11
Últimos 30 Días: 77
Todo El Tiempo: 6,812
