Saltar al contenido principal
Shure SM58 Grille Replacement
  1. Shure SM58 Grille Replacement, Grille: paso 1, imagen 1 de 1
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. Shure SM58 Grille Replacement: paso 2, imagen 1 de 2 Shure SM58 Grille Replacement: paso 2, imagen 2 de 2
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
Conclusión
Follow the steps in reverse to install the new grille on the microphone.
5 personas más completaron esta guía.
nat coll
Miembro Desde 09/27/12
642 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 7-53, Forte Fall 2012 Miembro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Miembros
20 Guías creadas
2 comentarios
Can you change the grilles of sm58 and sm86?
Jack - Contestar
Hello, I have two SM58 (wired), No matter how I tried to remove the grill from one of them, It just would not budge. With the other one, The grill comes off, but the base refuses to unscrew. Can you tell me how to solve this issue? Thanks in advance.
junia joseph - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 35
Todo El Tiempo: 10,021
