Saltar al contenido principal
Shure SM58 Capsule Installation Replacement
Qué necesitas
  1. Shure SM58 Capsule Installation Replacement, Collar: paso 1, imagen 1 de 3 Shure SM58 Capsule Installation Replacement, Collar: paso 1, imagen 2 de 3 Shure SM58 Capsule Installation Replacement, Collar: paso 1, imagen 3 de 3
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. Shure SM58 Capsule Installation Replacement, Faceplate: paso 2, imagen 1 de 1
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
  3. Shure SM58 Capsule Installation Replacement: paso 3, imagen 1 de 2 Shure SM58 Capsule Installation Replacement: paso 3, imagen 2 de 2
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
  4. Shure SM58 Capsule Installation Replacement: paso 4, imagen 1 de 2 Shure SM58 Capsule Installation Replacement: paso 4, imagen 2 de 2
    • Slide the face plate over the connector.
  5. Shure SM58 Capsule Installation Replacement, Capsule Installation: paso 5, imagen 1 de 2 Shure SM58 Capsule Installation Replacement, Capsule Installation: paso 5, imagen 2 de 2
    • Using an adjustable wrench, remove the nut and the washer behind the face plate by twisting the nut counterclockwise.
  6. Shure SM58 Capsule Installation Replacement: paso 6, imagen 1 de 1
    • Hold the body of the microphone, right below the grille, in one hand. Using your other hand, rotate the grille clockwise.
  7. Shure SM58 Capsule Installation Replacement: paso 7, imagen 1 de 1
    • Slide the grille off the top of the microphone once it is all the way loosened.
  8. Shure SM58 Capsule Installation Replacement: paso 8, imagen 1 de 3 Shure SM58 Capsule Installation Replacement: paso 8, imagen 2 de 3 Shure SM58 Capsule Installation Replacement: paso 8, imagen 3 de 3
    • Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
    • Slowly, pull upward while twisting the black plastic piece clockwise.
    • Be careful not to scratch the copper microphone capsule. Another face plate may fall out when removing capsule.
    • Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
Conclusión
Once installed, reassemble the microphone following the steps in reverse.
7 personas más completaron esta guía.
nat coll
Miembro Desde 09/27/12
642 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 7-53, Forte Fall 2012 Miembro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Miembros
20 Guías creadas
5 comentarios
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
Eanoid - Contestar
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
Daniel Berger -
Somehow the grill got really stuck and I want to replace it. It it screwed or is it as you've said - slidable?
arnold - Contestar
You can unscrew just the grill.
Burke McQuinn - Contestar
Hi, a bit unrelated but I accidentally twisted the black plastic piece slightly while everything was still intact. I turned it back though, did I damage the SM58 in any way?
Emje De - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 16
Ultimos 7 días: 48
Ultimos 30 días: 236
Todo El Tiempo: 39,206
