Saltar al contenido principal
Sharper Image SBT5002 Speaker Replacement
Qué necesitas
  1. Sharper Image SBT5002 Speaker Replacement, Back Panel: paso 1, imagen 1 de 2 Sharper Image SBT5002 Speaker Replacement, Back Panel: paso 1, imagen 2 de 2
    • Unplug the speaker before doing any work on it.
    • Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
  2. Sharper Image SBT5002 Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the back panel.
  3. Sharper Image SBT5002 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Remove the snap cable that connects the speaker to the circuit board.
  4. Sharper Image SBT5002 Speaker Replacement: paso 4, imagen 1 de 2 Sharper Image SBT5002 Speaker Replacement: paso 4, imagen 2 de 2
    • Use a tap hammer and a punch to release the 4 posts that hold the front panel in place.
  5. Sharper Image SBT5002 Speaker Replacement: paso 5, imagen 1 de 2 Sharper Image SBT5002 Speaker Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool or spudger to pry off the front panel.
  6. Sharper Image SBT5002 Speaker Replacement: paso 6, imagen 1 de 1
    • Use a#4 Phillips screwdriver to remove the four 9.5mm screws that secure the subwoofer to the woofer box.
  7. Sharper Image SBT5002 Speaker Replacement: paso 7, imagen 1 de 1
    • Remove the defective speaker.
Conclusión
Linda Freund
Miembro Desde 08/06/17
235 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 535
