Saltar al contenido principal
Sharp Aquos LC13B2UA Back Case Replacement
Qué necesitas
  1. Sharp Aquos LC13B2UA Back Case Replacement, Stand: paso 1, imagen 1 de 2 Sharp Aquos LC13B2UA Back Case Replacement, Stand: paso 1, imagen 2 de 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Back Case Replacement: paso 2, imagen 1 de 2 Sharp Aquos LC13B2UA Back Case Replacement: paso 2, imagen 2 de 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Back Case Replacement, Back Case: paso 3, imagen 1 de 3 Sharp Aquos LC13B2UA Back Case Replacement, Back Case: paso 3, imagen 2 de 3 Sharp Aquos LC13B2UA Back Case Replacement, Back Case: paso 3, imagen 3 de 3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Back Case Replacement: paso 4, imagen 1 de 2 Sharp Aquos LC13B2UA Back Case Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Back Case Replacement: paso 5, imagen 1 de 1
    • Using your hands, gently lift and remove the back case of the television.
Conclusión
Robert Hobson
Miembro Desde 01/20/11
1,290 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 1-11, Amido Winter 2011 Miembro de Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Miembros
9 Guías creadas
Un comentario
How do you remove the casing of a sharp LC26SB25E ? Please.
alan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 4,108
