Saltar al contenido principal
Shark Navigator Freestyle SV1106 Battery Pack Replacement
Qué necesitas
  1. Shark Navigator Freestyle SV1106 Battery Pack Replacement, Battery Pack: paso 1, imagen 1 de 1
    • Turn the device over to reveal the bottom of the motorized brush head.
  2. Shark Navigator Freestyle SV1106 Battery Pack Replacement: paso 2, imagen 1 de 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: paso 2, imagen 2 de 2
    • Slide the latch next to the panel upwards into the unlocked position.
  3. Shark Navigator Freestyle SV1106 Battery Pack Replacement: paso 3, imagen 1 de 1
    • Slide the panel to the right to reveal the battery.
  4. Shark Navigator Freestyle SV1106 Battery Pack Replacement: paso 4, imagen 1 de 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: paso 4, imagen 2 de 2
    • Pull the battery from the vacuum.
  5. Shark Navigator Freestyle SV1106 Battery Pack Replacement: paso 5, imagen 1 de 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
Conclusión
3 personas más completaron esta guía.
Zachary Liu
Miembro Desde 01/24/18
604 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G5, Livingston Winter 2018 Miembro de Cal Poly, Team S1-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G5
3 Miembros
10 Guías creadas
8 comentarios
How much is the part for the shark
sumi49 - Contestar
My Shark SV1106 doesn’t stay on very long. One episode you turn it on it immediately turns off. So what is the issue?
jklab23 - Contestar
How much is a battery pack?
ridgeite145 - Contestar
Items OrderedPrice1 of: 10.8V 3000mah Battery for Shark XBT1106N SV1110 SV1106N SV1110N SV11O6N SV116N Freestyle Navigator Cordless Stick Vacuum
Sold by: Areotek Direct (seller profile)
Condition: New
James Mayoral -
How much is a new battery pack for replacement
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 67
Todo El Tiempo: 10,752
