Saltar al contenido principal
Sega Genesis Motherboard Replacement
Qué necesitas
  1. Sega Genesis Motherboard Replacement, Outer Case: paso 1, imagen 1 de 1
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Sega Genesis Motherboard Replacement: paso 2, imagen 1 de 1
    • Flip the Sega Genesis upright.
  3. Sega Genesis Motherboard Replacement: paso 3, imagen 1 de 1
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Sega Genesis Motherboard Replacement: paso 4, imagen 1 de 1
    • Bend out the LED leads into vertical positions.
  5. Sega Genesis Motherboard Replacement: paso 5, imagen 1 de 1
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  6. Sega Genesis Motherboard Replacement: paso 6, imagen 1 de 1
    • Separate the main board from the outer case.
  7. Sega Genesis Motherboard Replacement, Motherboard: paso 7, imagen 1 de 1
    • Remove single black screw from the outside of the bottom cover, using a Philips screwdriver.
  8. Sega Genesis Motherboard Replacement: paso 8, imagen 1 de 1
    • Using a Philips screwdriver, remove 11 screws securing silver casing.
  9. Sega Genesis Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove silver case.
  10. Sega Genesis Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove single golden screw on motherboard using Philips screwdriver.
    • Note: Push headphone jack to the side.
  11. Sega Genesis Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove two black screws on the left and right sides of the cartridge slot.
  12. Sega Genesis Motherboard Replacement: paso 12, imagen 1 de 1
    • Remove motherboard.
  13. Sega Genesis Motherboard Replacement: paso 13, imagen 1 de 1
    • Re-install new motherboard.
Conclusión
13 personas más completaron esta guía.
Equipo
Cal Poly, Team 3-29, Regan Fall 2010 Miembro de Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 38
Ultimos 30 días: 207
Todo El Tiempo: 32,976
