Introducción
A guide to remove the GD-ROM from the Sega Dreamcast.
Partes
No se requieren partes.
Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Agregar Comentario
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Agregar Comentario
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
Agregar Comentario
Be gentle with the white controller cable as it can be a bit fragile. Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
  • Be gentle with the white controller cable as it can be a bit fragile.
  • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
Agregar Comentario
Remove the four 14mm Philips #02 screws located on the controller board. Remove the four 14mm Philips #02 screws located on the controller board.
  • Remove the four 14mm Philips #02 screws located on the controller board.
Agregar Comentario
Disconnect the white fan header from the controller port. Disconnect the white fan header from the controller port.
  • Disconnect the white fan header from the controller port.
Agregar Comentario
Remove the controller board by lifting it up from the controller port. Remove the controller board by lifting it up from the controller port.
  • Remove the controller board by lifting it up from the controller port.
Agregar Comentario
Conclusión
wkwong
Miembro Desde 14/11/09
402 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 5-1, Regan Fall 2009 Miembro de Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Miembros
23 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 31
Todo El Tiempo: 5,294
