Partes
No se requieren partes.
Using a Phillips head screwdriver remove  six screws from the bottom of the console. The six screws are marked.
  • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
Agregar Comentario
Remove the two screws that attach the Genesis' connector to the rest of the console.
  • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
Agregar Comentario
Slide the lock tab to the left to separate the halves of the console.
  • Slide the lock tab to the left to separate the halves of the console.
Agregar Comentario
Lift from the left side to remove the top of the case.
  • Lift from the left side to remove the top of the case.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using the spudger, pry the cover off of the Genesis attachment.
  • Using the spudger, pry the cover off of the Genesis attachment.
Agregar Comentario
Lift the top of the case to remove the cover.
  • Lift the top of the case to remove the cover.
Agregar Comentario
Remove the faceplate by pulling it up, then out.
  • Remove the faceplate by pulling it up, then out.
Agregar Comentario
Using a #00 Philips screwdriver remove the two screws that attach the Genesis adapter to the console. Disconnect the adapter from the console by carefully pulling the adapter out.
  • Using a #00 Philips screwdriver remove the two screws that attach the Genesis adapter to the console.
  • Disconnect the adapter from the console by carefully pulling the adapter out.
Agregar Comentario
Remove the four screws from the metal plate as shown using a #00 Philips screwdriver.
  • Remove the four screws from the metal plate as shown using a #00 Philips screwdriver.
    • The four half inch bronze screws are indicated by the yellow marking circles.
Agregar Comentario
Carefully remove the metal cover from the connector by sliding the cover up and out. Carefully remove the metal cover from the connector by sliding the cover up and out.
  • Carefully remove the metal cover from the connector by sliding the cover up and out.
Agregar Comentario
Remove the connector from the housing. Remove the connector from the housing.
  • Remove the connector from the housing.
Agregar Comentario
Conclusión
Ryan Kotzebue
Miembro Desde 07/10/10
243 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 5-14, Maness Fall 2010 Miembro de Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
5 Miembros
6 Guías creadas
So, I'm assuming you are doing this to correct a connection problem between the Sega CD and Genesis. Now that it's disassembled are you slightly bending the connections for a better fit, or cleaning the connectors to remove over 20 years of tarnish build up, or replacing all together with a new manufactured unit? By the way, I have my Sega CD and Genesis still to this day. They are in their original box with all the manuals and other pamphlets that they came with. I should see if Sherlock Holmes is still boring as it was when I first played it back in '91. Better yet play Night Trap and think about how controversial this game was at the time and even was pulled from store shelves, because of the controversy surrounding the girls outfits worn in the game.
helliant1 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 11
Todo El Tiempo: 4,421
