Saltar al contenido principal
Sceptre X9 Komodo VII Board Cover Replacement
Qué necesitas
  1. Sceptre X9 Komodo VII Board Cover Replacement, Stand: paso 1, imagen 1 de 1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Board Cover Replacement: paso 2, imagen 1 de 1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Board Cover Replacement, Board Cover: paso 3, imagen 1 de 1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Board Cover Replacement: paso 4, imagen 1 de 3 Sceptre X9 Komodo VII Board Cover Replacement: paso 4, imagen 2 de 3 Sceptre X9 Komodo VII Board Cover Replacement: paso 4, imagen 3 de 3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Board Cover Replacement: paso 5, imagen 1 de 2 Sceptre X9 Komodo VII Board Cover Replacement: paso 5, imagen 2 de 2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
Conclusión
Una persona más ha completado esta guía.
Ted Hsueh
Miembro Desde 09/20/12
170 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 16-56, Forte Fall 2012 Miembro de Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 14
Todo El Tiempo: 469
