Introducción
This guide helps you to remove and replace the lens unit
Partes
No se requieren partes.
Remove the five case screws with a Phillips #00 Screwdriver. Five 3.5mm Phillips Screws Five 3.5mm Phillips Screws
  • Remove the five case screws with a Phillips #00 Screwdriver.
  • Five 3.5mm Phillips Screws
Agregar Comentario
Gently lift up the back cover and set aside.
  • Gently lift up the back cover and set aside.
Agregar Comentario
Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector. Be careful not to rip out the ribbon connector.
  • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
  • Be careful not to rip out the ribbon connector.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger. Gently lift ribbon out of the gate and set screen aside.
  • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
  • Gently lift ribbon out of the gate and set screen aside.
Agregar Comentario
There are five screws of three different sizes which need removal. One 4.5mm screw
  • There are five screws of three different sizes which need removal.
  • One 4.5mm screw
  • Four 3.5mm screws, one on the button side
  • One 5.5mm screws
Agregar Comentario
Slowly lift metal tray to the right. Be careful not to bend the screw tabs or rip out the ribbon cable.
  • Slowly lift metal tray to the right.
  • Be careful not to bend the screw tabs or rip out the ribbon cable.
  • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
Agregar Comentario
Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
  • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
  • One gate is black and another is white.
Agregar Comentario
Remove the three silver screws. Three 5.5mm screws
  • Remove the three silver screws.
  • Three 5.5mm screws
Agregar Comentario
Lift the lens unit free of the camera.  A spudger can be used to separate the lens unit if necessary.
  • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 7-10, Maness Spring 2010 Miembro de Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 3,553
