Introducción
Use this guide to remove or replace the case.
Partes
No se requieren partes.
Place your thumb on the right side of the camera over the battery door.
  • Place your thumb on the right side of the camera over the battery door.
  • Slide the battery door to the right until the door lifts up.
Agregar Comentario
Remove and recycle old batteries.
  • Remove and recycle old batteries.
Agregar Comentario
Unscrew 6 Phillips screws using the #00 Phillips screwdriver. Two screws are on the left side of the camera. Two screws are on the right side of the camera.
  • Unscrew 6 Phillips screws using the #00 Phillips screwdriver.
    • Two screws are on the left side of the camera.
    • Two screws are on the right side of the camera.
    • Two screws are on the bottom of the camera.
Agregar Comentario
Open battery slot on the bottom of the camera by sliding the door to the right. Remove the 4 mm phillips screw on the bottom right using the #00 phillips screwdriver.
  • Open battery slot on the bottom of the camera by sliding the door to the right.
  • Remove the 4 mm phillips screw on the bottom right using the #00 phillips screwdriver.
Agregar Comentario
Insert spudger in the seam at the bottom of the camera. Gently separate the rear case from the front of the camera. Gently separate the rear case from the front of the camera.
  • Insert spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
Agregar Comentario
This step is only needed for the case and logic board replacement
  • This step is only needed for the case and logic board replacement
  • Using the #00 phillips screwdriver remove the screw attached to the front casing in the top left corner. Front case should easily separate.
Skip this step for the function set replacement.
Ariana Martinez - Contestar
This step is only needed for the case replacement.
  • This step is only needed for the case replacement.
  • Using the #00 phillips screwdriver remove the screw on the inside of the battery door.
  • Slide the battery door off of the hinge.
This step is needed only for the case replacement.
Conclusión
Equipo
Cal Poly, Team 24-24, Regan Spring 2010 Miembro de Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 3
Todo El Tiempo: 1,756
