Introducción
This guide does not require any prerequisite steps. Flip open the phone and begin the guide.
Partes
No se requieren partes.
With the flat end of  a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath. With the flat end of  a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver. Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
Agregar Comentario
Carefully pry the screen protector off the phone using the flat end of the spudger. This will require a bit of force as the back of the screen protector is lined with an adhesive material.
  • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
  • Once free from the adhesive, pull the screen protector away from the phone.
Agregar Comentario
Conclusión
StephenYH
Miembro Desde 11/03/13
20 Reputación
6 Guías creadas
Equipo
Clemson, Team 12-1, Benson Spring 2013 Miembro de Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Miembros
20 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 202
