Introducción
The microphone is a small, round piece that is located in a compartment behind the motherboard of the device. The motherboard must be removed first to reveal the microphone.
Partes
No se requieren partes.
Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone. While holding down the button, pull cover off with other hand. While holding down the button, pull cover off with other hand.
  • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
  • While holding down the button, pull cover off with other hand.
Agregar Comentario
Use fingers to grip the battery and remove it from the phone. Use fingers to grip the battery and remove it from the phone. Use fingers to grip the battery and remove it from the phone.
  • Use fingers to grip the battery and remove it from the phone.
Agregar Comentario
Using a spudger, remove the four rubber coverings on the lower back plate.
  • Using a spudger, remove the four rubber coverings on the lower back plate.
Agregar Comentario
Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate. Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate. Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
  • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
Agregar Comentario
Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate. Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate. Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
  • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
Agregar Comentario
Unscrew the 4.4mm screws at the top of the phone with the Tri-wing Y0 Screwdriver. Unscrew the 4.4mm screws at the top of the phone with the Tri-wing Y0 Screwdriver.
  • Unscrew the 4.4mm screws at the top of the phone with the Tri-wing Y0 Screwdriver.
Agregar Comentario
For the following steps, the phone is shown closed to make manipulating the parts easier. Using a spudger, remove the thin aluminum plate to access the upper motherboard. This will most likely be difficult to pry off and will take a considerable amount of force.  Stay clear of the piece to avoid injury when it comes free of the device.
  • For the following steps, the phone is shown closed to make manipulating the parts easier.
  • Using a spudger, remove the thin aluminum plate to access the upper motherboard.
    • This will most likely be difficult to pry off and will take a considerable amount of force. Stay clear of the piece to avoid injury when it comes free of the device.
Agregar Comentario
Use the flat end of the spudger to remove two ribbon cables from the back of the motherboard.
  • Use the flat end of the spudger to remove two ribbon cables from the back of the motherboard.
Agregar Comentario
Open the phone and firmly hold the phone casing with one hand and push the motherboard out of the case with the other by pushing on the keys. Once the keys are free from the casing, close the phone and pull the motherboard from the back of the phone the remainder of the way with your fingers. Once the keys are free from the casing, close the phone and pull the motherboard from the back of the phone the remainder of the way with your fingers.
  • Open the phone and firmly hold the phone casing with one hand and push the motherboard out of the case with the other by pushing on the keys.
  • Once the keys are free from the casing, close the phone and pull the motherboard from the back of the phone the remainder of the way with your fingers.
Agregar Comentario
Use fingers to grab the microphone and remove it from its housing. Use fingers to grab the microphone and remove it from its housing.
  • Use fingers to grab the microphone and remove it from its housing.
Agregar Comentario
Conclusión
Scott Perry
Miembro Desde 11/03/13
1 Reputación
2 Guías creadas
Equipo
Clemson, Team 12-1, Benson Spring 2013 Miembro de Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Miembros
20 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 182
