Saltar al contenido principal
Sansa e260R Scroll Wheel Replacement
Qué necesitas
  1. Sansa e260R Scroll Wheel Replacement, Rear Case: paso 1, imagen 1 de 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Scroll Wheel Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Scroll Wheel Replacement: paso 3, imagen 1 de 1
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Scroll Wheel Replacement, Battery: paso 4, imagen 1 de 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Scroll Wheel Replacement, Front Panel: paso 5, imagen 1 de 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Scroll Wheel Replacement: paso 6, imagen 1 de 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Scroll Wheel Replacement: paso 7, imagen 1 de 2 Sansa e260R Scroll Wheel Replacement: paso 7, imagen 2 de 2
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Scroll Wheel Replacement, Scroll Wheel: paso 8, imagen 1 de 2 Sansa e260R Scroll Wheel Replacement, Scroll Wheel: paso 8, imagen 2 de 2
    • Gently pry the bottom of the black button to remove it from the device.
  9. Sansa e260R Scroll Wheel Replacement: paso 9, imagen 1 de 2 Sansa e260R Scroll Wheel Replacement: paso 9, imagen 2 de 2
    • There are 4 small metal hooks under the white scrolling mechanism.
    • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
  10. Sansa e260R Scroll Wheel Replacement: paso 10, imagen 1 de 1
    • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
Conclusión
6 personas más completaron esta guía.
JenniferW
Miembro Desde 01/31/12
194 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-15, Maness Winter 2012 Miembro de Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Miembros
5 Guías creadas
Un comentario
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
Lloyd Merriam - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 3,232
