Before disassembling the device, make sure it is powered off.
  • Before disassembling the device, make sure it is powered off.
  • Remove the four 1.5mm screws on the back of the device.
Agregar Comentario
Using a plastic opening tool, lift the metal backing from the front of the device.
  • Using a plastic opening tool, lift the metal backing from the front of the device.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull the rear panel off of the Sansa e260R.
  • Pull the rear panel off of the Sansa e260R.
Agregar Comentario
Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Casey Smith
Miembro Desde 20/01/12
87 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 8-15, Maness Winter 2012 Miembro de Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 2,096
