Introducción
This guide will give you step by step directions on how to replace a Sanitaire SC684 Belt.
Herramientas
No se requieren herramientas.
Partes
Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
  • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
  • Lay vacuum on its back
Agregar Comentario
Find the bottom metal plate and identify the two latches on either side of the vacuum.
  • Find the bottom metal plate and identify the two latches on either side of the vacuum.
  • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
Agregar Comentario
Lift off the metal plate by pulling it towards you.
  • Lift off the metal plate by pulling it towards you.
Agregar Comentario
Identify the belt and brush roller.
  • Identify the belt and brush roller.
  • The belt is a black circle made of rubber.
  • The brush roller has bristles and is tube shaped.
Agregar Comentario
Slide the belt off of the circular knob.
  • Slide the belt off of the circular knob.
Agregar Comentario
Pull brush roller out and detach the belt off the brush roller. Pull brush roller out and detach the belt off the brush roller.
  • Pull brush roller out and detach the belt off the brush roller.
Agregar Comentario
Conclusión
Caycie Pascual
Miembro Desde 26/09/12
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 16-58, Forte Fall 2012 Miembro de Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,889
