Saltar al contenido principal
Samsung SPH-A500 Logic Board Replacement
Qué necesitas
  1. Samsung SPH-A500 Logic Board Replacement, Logic Board: paso 1, imagen 1 de 1
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Samsung SPH-A500 Logic Board Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Samsung SPH-A500 Logic Board Replacement: paso 3, imagen 1 de 1
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Samsung SPH-A500 Logic Board Replacement: paso 4, imagen 1 de 1
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  5. Samsung SPH-A500 Logic Board Replacement: paso 5, imagen 1 de 1
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Do not completely pull out the circuit board.
  6. Samsung SPH-A500 Logic Board Replacement: paso 6, imagen 1 de 1
    • Look for the clip at the top right corner of the logic board.
  7. Samsung SPH-A500 Logic Board Replacement: paso 7, imagen 1 de 1
    • Remove the clip from the logic board.
  8. Samsung SPH-A500 Logic Board Replacement: paso 8, imagen 1 de 1
    • Remove the logic board.
    • Replace the broken logic board with a new one.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 18-100, Johann Spring 2010 Miembro de Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 2,046
