Saltar al contenido principal
Samsung SPH-A500 Front LCD Display Replacement
Qué necesitas
  1. Samsung SPH-A500 Front LCD Display Replacement, Front LCD Display: paso 1, imagen 1 de 1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Front LCD Display Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Front LCD Display Replacement: paso 3, imagen 1 de 1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Front LCD Display Replacement: paso 4, imagen 1 de 1
    • The LCD screen is big, rectangular screen in the center of the logic board.
  5. Samsung SPH-A500 Front LCD Display Replacement: paso 5, imagen 1 de 1
    • Remove the glue and black tape that is attached to the LCD screen
  6. Samsung SPH-A500 Front LCD Display Replacement: paso 6, imagen 1 de 1
    • Remove Broken LCD Screen.
  7. Samsung SPH-A500 Front LCD Display Replacement: paso 7, imagen 1 de 1
    • Attach the New LCD Screen, with wire point up and out to the black connector.
    • Note: Super Glue may be required to permanently attach LCD to the black connector
Conclusión
Derek Panger
Miembro Desde 04/16/10
21 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-100, Johann Spring 2010 Miembro de Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 2,441
