First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
  • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
Agregar Comentario
Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
  • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
Agregar Comentario
As shown above, with a plastic pry tool, begin working at the top corner and down each side.  The face plate has 10 tabs that hook into the phone's body. Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
  • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
  • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
  • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Continue down each side toward the bottom with your pry tool. Note: It may help to use multiple pry tools to help hold it open.
  • Continue down each side toward the bottom with your pry tool.
  • Note: It may help to use multiple pry tools to help hold it open.
  • Second photo: location of the tabs.
Agregar Comentario
With 8 tabs released, the face plate is nearly free. With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
  • With 8 tabs released, the face plate is nearly free.
  • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
  • Note: A strip of double sided tape holds the faceplate, so expect some resistance
Agregar Comentario
Remove the 2 speakers by gently prying them up. The speakers are attached with double sided tape.
  • Remove the 2 speakers by gently prying them up.
  • The speakers are attached with double sided tape.
Agregar Comentario
With the speakers free from the phones body the screen is loose as well.
  • With the speakers free from the phones body the screen is loose as well.
  • The desired solder joint can be accessed to attach a new speaker.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Matthew Hove
Miembro Desde 05/01/11
1,031 Reputación
20 Guías creadas
Equipo
Cal Poly, Team 3-40, Regan Winter 2011 Miembro de Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Miembros
20 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 1,532
