Qué necesitas
Begin by inserting the pry tool near the charger jack.
There are 4 tabs to release.
Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
Loosen the 2 side tabs before moving on to the top two.
See the second photo to see location of the tabs.
Be careful of the ribbon wires shown in second photo.
First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
Note: The bottom 2 are the most challenging to remove.
Note: When reassembling start with the bottom two tabs.
Use an opening tool to gently lift the ribbon wire connection to the screen.
2 personas más completaron esta guía.
