Partes
No se requieren partes.
Remove the 4 (4.7mm) philips head screws.
  • Remove the 4 (4.7mm) philips head screws.
Agregar Comentario
Unplug the rubber charger outlet cover.
  • Unplug the rubber charger outlet cover.
Agregar Comentario
Unplug the rubber headset jack cover.
  • Unplug the rubber headset jack cover.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Begin by inserting the pry tool near the charger jack. There are 4 tabs to release.
  • Begin by inserting the pry tool near the charger jack.
  • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
  • Loosen the 2 side tabs before moving on to the top two.
  • See the second photo to see location of the tabs.
  • Be careful of the ribbon wires shown in second photo.
Agregar Comentario
Once the two side tabs are free; gently pry the white backing down to release the top two tabs. Hold the phone with the left hand as shown
  • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
  • Hold the phone with the left hand as shown
  • Wiggle the white backplate from side to side while pulling down with the right hand.
Agregar Comentario
Remove the ribbon wires connecting to the screen using the pry tool.
  • Remove the ribbon wires connecting to the screen using the pry tool.
Agregar Comentario
2 tabs hold the motherboard in place.
  • 2 tabs hold the motherboard in place.
  • Release the labeled tabs with the pry tool from the location shown.
Agregar Comentario
Separate the motherboard from the phone.
  • Separate the motherboard from the phone.
Agregar Comentario
Conclusión
Matthew Hove
Miembro Desde 05/01/11
1,031 Reputación
20 Guías creadas
Equipo
Cal Poly, Team 3-40, Regan Winter 2011 Miembro de Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Miembros
20 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 1,734
