Saltar al contenido principal
Samsung SGH-X105 Logic Board Replacement
Qué necesitas
  1. Samsung SGH-X105 Logic Board Replacement, Battery: paso 1, imagen 1 de 1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Logic Board Replacement: paso 2, imagen 1 de 3 Samsung SGH-X105 Logic Board Replacement: paso 2, imagen 2 de 3 Samsung SGH-X105 Logic Board Replacement: paso 2, imagen 3 de 3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Logic Board Replacement, Front & Back Panels: paso 3, imagen 1 de 1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Logic Board Replacement: paso 4, imagen 1 de 3 Samsung SGH-X105 Logic Board Replacement: paso 4, imagen 2 de 3 Samsung SGH-X105 Logic Board Replacement: paso 4, imagen 3 de 3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Logic Board Replacement: paso 5, imagen 1 de 2 Samsung SGH-X105 Logic Board Replacement: paso 5, imagen 2 de 2
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Logic Board Replacement, Logic Board: paso 6, imagen 1 de 3 Samsung SGH-X105 Logic Board Replacement, Logic Board: paso 6, imagen 2 de 3 Samsung SGH-X105 Logic Board Replacement, Logic Board: paso 6, imagen 3 de 3
    • Gently remove the logic board and LCD screen from the back cover of the phone.
  7. Samsung SGH-X105 Logic Board Replacement: paso 7, imagen 1 de 1
    • Remove the two screws above the LCD screen with a Phillips #00 screw driver. These connect to the white plastic cover in which the speaker is housed located on the reverse side of the logic board.
    • Make sure the white plastic cover remains in contact with the logic board while removing the screws.
  8. Samsung SGH-X105 Logic Board Replacement: paso 8, imagen 1 de 3 Samsung SGH-X105 Logic Board Replacement: paso 8, imagen 2 de 3 Samsung SGH-X105 Logic Board Replacement: paso 8, imagen 3 de 3
    • Rotate the logic board so that the LCD screen is face down.
    • Make sure the white plastic cover remains in contact with the logic board while it is being rotated.
    • Screws may fall out as the object is rotated.
  9. Samsung SGH-X105 Logic Board Replacement: paso 9, imagen 1 de 2 Samsung SGH-X105 Logic Board Replacement: paso 9, imagen 2 de 2
    • Gently begin to separate the white plastic cover from the logic board.
    • This cover will be connected by two small wires. Be sure not to break this connection.
  10. Samsung SGH-X105 Logic Board Replacement: paso 10, imagen 1 de 2 Samsung SGH-X105 Logic Board Replacement: paso 10, imagen 2 de 2
    • Locate the two wires (black and red) which connect the speaker to the logic board.
    • Using your nails, tweezers, or any precise grabbing tool, pinch the speaker connector (clear plastic plug that goes into the logic board) and pull gently. It should pop out easily.
    • Once the wires are disconnected and the screws removed, the white plastic cover can easily be removed from the logic board.
Conclusión
DJ Tarazona
Miembro Desde 04/13/10
58 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 28-29, Regan Spring 2010 Miembro de Cal Poly, Team 28-29, Regan Spring 2010
CPSU-REGAN-S10S28G29
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,923
