Saltar al contenido principal
Samsung SGH-X105 Earpiece Speaker Replacement
Qué necesitas
  1. Samsung SGH-X105 Earpiece Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Earpiece Speaker Replacement: paso 2, imagen 1 de 3 Samsung SGH-X105 Earpiece Speaker Replacement: paso 2, imagen 2 de 3 Samsung SGH-X105 Earpiece Speaker Replacement: paso 2, imagen 3 de 3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Earpiece Speaker Replacement, Front & Back Panels: paso 3, imagen 1 de 1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Earpiece Speaker Replacement: paso 4, imagen 1 de 3 Samsung SGH-X105 Earpiece Speaker Replacement: paso 4, imagen 2 de 3 Samsung SGH-X105 Earpiece Speaker Replacement: paso 4, imagen 3 de 3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Earpiece Speaker Replacement: paso 5, imagen 1 de 2 Samsung SGH-X105 Earpiece Speaker Replacement: paso 5, imagen 2 de 2
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Earpiece Speaker Replacement, Earpiece Speaker: paso 6, imagen 1 de 1
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Samsung SGH-X105 Earpiece Speaker Replacement: paso 7, imagen 1 de 3 Samsung SGH-X105 Earpiece Speaker Replacement: paso 7, imagen 2 de 3 Samsung SGH-X105 Earpiece Speaker Replacement: paso 7, imagen 3 de 3
    • Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover.
    • The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened.
    • You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
Conclusión
Una persona más ha completado esta guía.
Chris Lao
Miembro Desde 04/15/10
16 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 28-29, Regan Spring 2010 Miembro de Cal Poly, Team 28-29, Regan Spring 2010
CPSU-REGAN-S10S28G29
4 Miembros
12 Guías creadas
Un comentario
Where can I get a replacement speaker?
NickyPhils - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,940
