Introducción
Items needed:
You will need a wedge shaped tool in order to pry open the front panel of cell phone and a screwdriver.
Remove the plastic coverings at the base of the LCD screen using your fingers. Remove the plastic coverings at the base of the LCD screen using your fingers.
  • Remove the plastic coverings at the base of the LCD screen using your fingers.
Agregar Comentario
Remove the two 4.5mm screws located underneath the plastic coverings.
  • Remove the two 4.5mm screws located underneath the plastic coverings.
  • You may want to use tweezers to remove the loosened screws.
Agregar Comentario
Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
  • Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
  • Gently pry the top panel off around the entire frame.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Make sure that the top panel is completely separated from the LCD display around the entire perimeter. Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
  • Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
Agregar Comentario
Remove the top panel.
  • Remove the top panel.
Agregar Comentario
Detach the connecting wire panel from the LCD display system. Detach the connecting wire panel from the LCD display system.
  • Detach the connecting wire panel from the LCD display system.
Agregar Comentario
Using tweezers, remove the camera from the cellphone casing. Using tweezers, remove the camera from the cellphone casing.
  • Using tweezers, remove the camera from the cellphone casing.
Agregar Comentario
Conclusión
Michael Strange
Miembro Desde 30/01/11
101 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-23, Maness Winter 2011 Miembro de Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 1,319
