Introducción
This repair guide shows how to remove and replace the logic board.
Partes
No se requieren partes.
Put the phone face down so that the battery cover is showing. Put the phone face down so that the battery cover is showing.
  • Put the phone face down so that the battery cover is showing.
Agregar Comentario
Use your thumb to push the cover down and off. Lift the battery off the device.
  • Use your thumb to push the cover down and off.
  • Lift the battery off the device.
Agregar Comentario
Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown. Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
  • Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
Agregar Comentario
Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device. Note: some force must be applied when removing back cover. Note: some force must be applied when removing back cover.
  • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
  • Note: some force must be applied when removing back cover.
Agregar Comentario
Detach the tab from the logic board by using iPod Opening Tool (as shown).
  • Detach the tab from the logic board by using iPod Opening Tool (as shown).
Agregar Comentario
Use iPod Opening Tool to lift the green logic board carefully. Remove logic board from the device and replace with new one.
  • Use iPod Opening Tool to lift the green logic board carefully.
  • Remove logic board from the device and replace with new one.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 29-81, Johann Spring 2010 Miembro de Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,689
