Introducción
Use this guide to replace your Samsung SGH A707 phone's display.
Press on the markings on the cover and pull it down to reveal the battery.
  • Press on the markings on the cover and pull it down to reveal the battery.
Agregar Comentario
Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
  • Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
Agregar Comentario
Here is the phone without the battery.
  • Here is the phone without the battery.
Agregar Comentario
Unscrew the six screws on the back of the phone using the Phillips #0 screw driver. Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
  • Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
Agregar Comentario
Use the prying tool the pry off the phone's plastic frame.
  • Use the prying tool the pry off the phone's plastic frame.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use the prying tool to disconnect the rectangular connector. Use the prying tool to disconnect the rectangular connector. Use the prying tool to disconnect the rectangular connector.
  • Use the prying tool to disconnect the rectangular connector.
Agregar Comentario
Use the prying tool to disconnect the small connector.
  • Use the prying tool to disconnect the small connector.
Agregar Comentario
Gently pull off the circuit board.
  • Gently pull off the circuit board.
Agregar Comentario
Here is the phone without the logic board.
  • Here is the phone without the logic board.
Agregar Comentario
Use the Phillips #0 screw driver to remove the two screws. Place the screws in a safe place.
  • Use the Phillips #0 screw driver to remove the two screws.
  • Place the screws in a safe place.
  • Use the prying tool to gently pry the screen off, by slowly moving the prying tool around the entire edge of the screen (roughly highlighted with a red rectangle). You must be very gentle, otherwise the screen will crack.
Agregar Comentario
Now we have access to the camera.
  • Now we have access to the camera.
  • We also have access to the speakers.
  • Disconnect the flat cable to separate the two pieces.
Agregar Comentario
Samsung SGH A707
  • Samsung SGH A707
Agregar Comentario
Separate the two flaps to make handling easier.
  • Separate the two flaps to make handling easier.
  • Use a screw driver to press a latch in along the axis of the hinge and simultaneously pull the pieces apart.
  • Gently pull the flat cable through the hinge.
Agregar Comentario
Use the prying tool to separate the screen from the rest of the phone.
  • Use the prying tool to separate the screen from the rest of the phone.
  • Be careful not to lose the little cube of foam and wire that is under the circuit board. It is important in connecting two different circuits and must be placed back when the phone is reassembled.
Agregar Comentario
Samsung SGH A707 Samsung SGH A707
  • Samsung SGH A707
Agregar Comentario
Conclusión
yfm
Miembro Desde 06/11/12
10 Reputación
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 7
Todo El Tiempo: 1,026
