Introducción
This guide will cover the removal of the Samsung SCH-U340 top casing.
Partes
No se requieren partes.
Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
  • Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
Agregar Comentario
Pull battery up from indent at the bottom and slide it out.
  • Pull battery up from indent at the bottom and slide it out.
Agregar Comentario
Set the battery aside.
  • Set the battery aside.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs. First remove the plastic plugs covering the screws with a spudger.
  • The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs. First remove the plastic plugs covering the screws with a spudger.
Agregar Comentario
Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver. They will need to be pried out after unscrewing them due to their size. Take care not to lose the screws as they are small and have a tendency to roll.
  • Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver. They will need to be pried out after unscrewing them due to their size. Take care not to lose the screws as they are small and have a tendency to roll.
Agregar Comentario
The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
  • The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
    • To begin removing the outer cover start by prying the large tab up with a flat object.
Agregar Comentario
Continue to pry each tab up, taking care not to break the tabs.
  • Continue to pry each tab up, taking care not to break the tabs.
  • If disaster strikes and a tab is broken, the outer casing can still be put back on assuming the majority of the tabs are still intact.
Agregar Comentario
After the last tab is removed, tug gently on the outer casing to remove it. Don't pull too hard, or you may damage the wires connected to the speaker.
  • After the last tab is removed, tug gently on the outer casing to remove it. Don't pull too hard, or you may damage the wires connected to the speaker.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 3-21, Maness Winter 2010 Miembro de Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 2,512
