Saltar al contenido principal
Samsung SCH-U340 Lower Casing Replacement
Qué necesitas
  1. Samsung SCH-U340 Lower Casing Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Lower Casing Replacement: paso 2, imagen 1 de 1
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Lower Casing Replacement: paso 3, imagen 1 de 1
    • Set the battery aside.
  4. Samsung SCH-U340 Lower Casing Replacement, Lower Casing: paso 4, imagen 1 de 1
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Lower Casing Replacement: paso 5, imagen 1 de 2 Samsung SCH-U340 Lower Casing Replacement: paso 5, imagen 2 de 2
    • Use a spudger to pry the back assembly off of the device.
Conclusión
Equipo
Cal Poly, Team 3-21, Maness Winter 2010 Miembro de Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 3,606
