Introducción
The screen casing may become worn or broken over time. This guide will allow you to remove/replace it.
Qué necesitas
After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
Casi Terminas!
Conclusión
