Saltar al contenido principal
Samsung SCH-A670 Keypad Replacement
Qué necesitas
  1. Samsung SCH-A670 Keypad Replacement, Battery Cover: paso 1, imagen 1 de 1
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Keypad Replacement, Battery: paso 2, imagen 1 de 1
    • Remove the battery.
  3. Samsung SCH-A670 Keypad Replacement, Logic Board: paso 3, imagen 1 de 1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Keypad Replacement: paso 4, imagen 1 de 1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Keypad Replacement: paso 5, imagen 1 de 1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Keypad Replacement: paso 6, imagen 1 de 2 Samsung SCH-A670 Keypad Replacement: paso 6, imagen 2 de 2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Keypad Replacement: paso 7, imagen 1 de 1
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Keypad Replacement: paso 8, imagen 1 de 1
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Keypad Replacement, Keypad: paso 9, imagen 1 de 1
    • Once the logic board has been removed, peel the keypad up.
Conclusión
Nathan Brink
Miembro Desde 04/11/10
19 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 34-59, Forte Spring 2010 Miembro de Cal Poly, Team 34-59, Forte Spring 2010
CPSU-FORTE-S10S34G59
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 1,567
