Remove the battery by pressing the button at the top of the case.
  • Remove the battery by pressing the button at the top of the case.
Agregar Comentario
Unscrew the antenna by twisting it counter-clockwise until it is loose. Slide the antenna out of the phone. The black casing can be removed from the old antenna and used for the new antenna.
  • Unscrew the antenna by twisting it counter-clockwise until it is loose.
  • Slide the antenna out of the phone.
  • The black casing can be removed from the old antenna and used for the new antenna.
Agregar Comentario
Conclusión
Aaron Epstein
Miembro Desde 20/01/12
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-23, Maness Winter 2012 Miembro de Cal Poly, Team 11-23, Maness Winter 2012
CPSU-MANESS-W12S11G23
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 972
