Introducción
This guide will teach you how to get to and install the back case of the phone.
Partes
No se requieren partes.
To separate the battery from the phone, use your thumb to push in the button as shown. Keep the unlock button pressed as you slide the battery away from the button. Pull the battery away from the phone.
  • To separate the battery from the phone, use your thumb to push in the button as shown.
  • Keep the unlock button pressed as you slide the battery away from the button.
  • Pull the battery away from the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a T6 Torx screwdriver to remove the highlighted screws. These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace. Carefully pry apart the two pieces, laying the back case to the side.
  • Use a T6 Torx screwdriver to remove the highlighted screws.
  • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
  • Carefully pry apart the two pieces, laying the back case to the side.
Agregar Comentario
Conclusión
Will Gunter
Miembro Desde 23/10/12
1 Reputación
8 Guías creadas
Equipo
Clemson, Team 14-6, Benson Fall 2012 Miembro de Clemson, Team 14-6, Benson Fall 2012
CLEM-BENSON-F12S14G6
3 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 195
