Partes
No se requieren partes.
Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
  • Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
Agregar Comentario
Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
  • Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
Agregar Comentario
Lift battery away from phone case.
  • Lift battery away from phone case.
  • The battery is now removed from the device. Congratulations.
Agregar Comentario
Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
  • Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
Agregar Comentario
When unscrewed, pull the antenna straight up and out.
  • When unscrewed, pull the antenna straight up and out.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional). The antenna and its guide tube are now removed from the phone. Congratulations.
  • Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional).
  • The antenna and its guide tube are now removed from the phone. Congratulations.
Agregar Comentario
Remove the four screws using a T6 Torx screwdriver.
  • Remove the four screws using a T6 Torx screwdriver.
Agregar Comentario
Work from the bottom of the phone, separating the two halves of the case. Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
  • Work from the bottom of the phone, separating the two halves of the case.
  • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
Agregar Comentario
Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
  • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
  • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
Agregar Comentario
Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end. The Back Cover is now removed. Congratulations. The Back Cover is now removed. Congratulations.
  • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
  • The Back Cover is now removed. Congratulations.
Agregar Comentario
Remove the connector for the earpiece speaker, located on the upper end of the logic board.
  • Remove the connector for the earpiece speaker, located on the upper end of the logic board.
Agregar Comentario
Turn the front cover over, gently prying the logic board away from the front cover. It will remain attached by two wires from the front of the board.
  • Turn the front cover over, gently prying the logic board away from the front cover. It will remain attached by two wires from the front of the board.
Agregar Comentario
Work the microphone out of its socket on the front cover; it will remain attached to the logic board, its wires are soldered. The logic board is now removed from the phone. Congratulations.
  • Work the microphone out of its socket on the front cover; it will remain attached to the logic board, its wires are soldered.
  • The logic board is now removed from the phone. Congratulations.
Agregar Comentario
Turn the front cover over and shake the keys out of it. They should come free in a single piece. Note: The keypad may accidentally come free while removing rear cover or logic board. It is best to remove the logic board to reinstall the key mat.
  • Turn the front cover over and shake the keys out of it. They should come free in a single piece.
  • Note: The keypad may accidentally come free while removing rear cover or logic board. It is best to remove the logic board to reinstall the key mat.
  • The key pad is now removed from the phone. Congratulations.
Agregar Comentario
Conclusión
Equipo
Clemson, Team 2-6, Benson Spring 2012 Miembro de Clemson, Team 2-6, Benson Spring 2012
CLEM-BENSON-S12S2G6
2 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 733
