Saltar al contenido principal
Samsung SCH-3500 Back Cover Replacement
Qué necesitas
  1. Samsung SCH-3500 Back Cover Replacement, Battery: paso 1, imagen 1 de 2 Samsung SCH-3500 Back Cover Replacement, Battery: paso 1, imagen 2 de 2
    • Place the phone so that the back is facing you. Depress the locking tab on the back of the phone with a finger or thumb.
  2. Samsung SCH-3500 Back Cover Replacement: paso 2, imagen 1 de 1
    • Slide the battery toward bottom of the phone, about a quarter of an inch, to clear the hooks that keep it secured to the back of the phone.
  3. Samsung SCH-3500 Back Cover Replacement: paso 3, imagen 1 de 1
    • Lift the battery away from the phone case.
  4. Samsung SCH-3500 Back Cover Replacement, Antenna: paso 4, imagen 1 de 2 Samsung SCH-3500 Back Cover Replacement, Antenna: paso 4, imagen 2 de 2
    • Grasp the antenna firmly and rotate it counterclockwise to unscrew it from the phone.
  5. Samsung SCH-3500 Back Cover Replacement: paso 5, imagen 1 de 1
    • When unscrewed, pull the antenna straight up and out.
  6. Samsung SCH-3500 Back Cover Replacement: paso 6, imagen 1 de 2 Samsung SCH-3500 Back Cover Replacement: paso 6, imagen 2 de 2
    • Pull the guide tube free from its retaining ring and slide it out the top.
  7. Samsung SCH-3500 Back Cover Replacement, Back Cover: paso 7, imagen 1 de 1
    • Remove the four screws using a T6 Torx screwdriver.
  8. Samsung SCH-3500 Back Cover Replacement: paso 8, imagen 1 de 2 Samsung SCH-3500 Back Cover Replacement: paso 8, imagen 2 de 2
    • Work from the bottom of the phone, separating the two halves of the case.
    • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
  9. Samsung SCH-3500 Back Cover Replacement: paso 9, imagen 1 de 1
    • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
  10. Samsung SCH-3500 Back Cover Replacement: paso 10, imagen 1 de 3 Samsung SCH-3500 Back Cover Replacement: paso 10, imagen 2 de 3 Samsung SCH-3500 Back Cover Replacement: paso 10, imagen 3 de 3
    • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
    • The Back Cover is now removed. Congratulations.
Conclusión
Una persona más ha completado esta guía.
Equipo
Clemson, Team 2-6, Benson Spring 2012 Miembro de Clemson, Team 2-6, Benson Spring 2012
CLEM-BENSON-S12S2G6
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 609
