Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
  • Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
Agregar Comentario
Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
  • Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Lift battery away from phone case.
  • Lift battery away from phone case.
  • The battery is now removed from the device. Congratulations.
Agregar Comentario
Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
  • Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
Agregar Comentario
When unscrewed, pull the antenna straight up and out.
  • When unscrewed, pull the antenna straight up and out.
Agregar Comentario
Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional). The antenna and its guide tube are now removed from the phone. Congratulations.
  • Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional).
  • The antenna and its guide tube are now removed from the phone. Congratulations.
Agregar Comentario
Conclusión
Equipo
Clemson, Team 2-6, Benson Spring 2012 Miembro de Clemson, Team 2-6, Benson Spring 2012
CLEM-BENSON-S12S2G6
2 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 6
Todo El Tiempo: 609
