Saltar al contenido principal
Samsung S860 LCD Screen Replacement
Qué necesitas
  1. Samsung S860 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 2 Samsung S860 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 2
    • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
  2. Samsung S860 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Slide open the battery compartment cover before removing the exterior covers of the camera.
  3. Samsung S860 LCD Screen Replacement: paso 3, imagen 1 de 3 Samsung S860 LCD Screen Replacement: paso 3, imagen 2 de 3 Samsung S860 LCD Screen Replacement: paso 3, imagen 3 de 3
    • Carefully pull the back case (the side showing the LCD screen) away from the front half.
    • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
    • Turn the camera around to the front (the lens side). Carefully remove the front case.
    • There are also clips on the lens' side as well, so do not be afraid to use force.
  4. Samsung S860 LCD Screen Replacement: paso 4, imagen 1 de 2 Samsung S860 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Position the camera so the LCD screen is facing you.
    • Remove the LCD screen from the screen plate.
    • Replace the broken LCD screen with the functioning LCD screen.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 33-72, Johann Spring 2010 Miembro de Cal Poly, Team 33-72, Johann Spring 2010
CPSU-JOHANN-S10S33G72
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 8,842
