Saltar al contenido principal
Samsung Rogue Front Function Keys Replacement
Qué necesitas
  1. Samsung Rogue Front Function Keys Replacement, Battery: paso 1, imagen 1 de 2 Samsung Rogue Front Function Keys Replacement, Battery: paso 1, imagen 2 de 2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Front Function Keys Replacement: paso 2, imagen 1 de 2 Samsung Rogue Front Function Keys Replacement: paso 2, imagen 2 de 2
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Front Function Keys Replacement, Motherboard: paso 3, imagen 1 de 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Front Function Keys Replacement: paso 4, imagen 1 de 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Front Function Keys Replacement: paso 5, imagen 1 de 3 Samsung Rogue Front Function Keys Replacement: paso 5, imagen 2 de 3 Samsung Rogue Front Function Keys Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Front Function Keys Replacement: paso 6, imagen 1 de 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Front Function Keys Replacement: paso 7, imagen 1 de 2 Samsung Rogue Front Function Keys Replacement: paso 7, imagen 2 de 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Front Function Keys Replacement: paso 8, imagen 1 de 2 Samsung Rogue Front Function Keys Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Front Function Keys Replacement, Front Function Keys: paso 9, imagen 1 de 1
    • Remove the eight 1.7mm Philips screws above the keyboard.
  10. Samsung Rogue Front Function Keys Replacement: paso 10, imagen 1 de 1
    • Carefully remove keyboard frame from the sliding mechanisms underneath.
  11. Samsung Rogue Front Function Keys Replacement: paso 11, imagen 1 de 1
    • Remove the five 3.0mm Philips screws around the outside of the sliding mechanisms.
  12. Samsung Rogue Front Function Keys Replacement: paso 12, imagen 1 de 3 Samsung Rogue Front Function Keys Replacement: paso 12, imagen 2 de 3 Samsung Rogue Front Function Keys Replacement: paso 12, imagen 3 de 3
    • Use a plastic opening tool to pry off the upper slide plate.
    • Be careful of the film of wires when taking off the upper slide plate.
  13. Samsung Rogue Front Function Keys Replacement: paso 13, imagen 1 de 3 Samsung Rogue Front Function Keys Replacement: paso 13, imagen 2 de 3 Samsung Rogue Front Function Keys Replacement: paso 13, imagen 3 de 3
    • Use tweezers to open the two black gates by putting them in the "up" position.
    • With the same tweezers, carefully pull out the orange strips from the two specified gates.
  14. Samsung Rogue Front Function Keys Replacement: paso 14, imagen 1 de 3 Samsung Rogue Front Function Keys Replacement: paso 14, imagen 2 de 3 Samsung Rogue Front Function Keys Replacement: paso 14, imagen 3 de 3
    • Using tweezers, gently remove the bottom orange strip from the device.
    • At this point you can easily lift out the rubber function key pad as well.
  15. Samsung Rogue Front Function Keys Replacement: paso 15, imagen 1 de 3 Samsung Rogue Front Function Keys Replacement: paso 15, imagen 2 de 3 Samsung Rogue Front Function Keys Replacement: paso 15, imagen 3 de 3
    • There are two ways you can take out the front function keys:
    • 1) Use a plastic phone opening tool to pry out the piece from the front of the phone.
    • 2) Simply pop out the piece from the inside by pushing on its tabs.
Conclusión
Equipo
Cal Poly, Team 7-32, Maness Spring 2012 Miembro de Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 352
