Introducción
In some cases, the motherboard of a device may stop working due to installment issues or a short circuit. Either way, we have created a user-friendly guide that will show you how to fix your device
Partes
No se requieren partes.
Start by removing the back plate and battery of the phone.
  • Start by removing the back plate and battery of the phone.
Agregar Comentario
Using a Phillip’s #00 screwdriver, unscrew the 6 screws located on the back of the device. Using a Phillip’s #00 screwdriver, unscrew the 6 screws located on the back of the device.
  • Using a Phillip’s #00 screwdriver, unscrew the 6 screws located on the back of the device.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the casing from the back of the device. Remove the casing from the back of the device.
  • Remove the casing from the back of the device.
Agregar Comentario
Next, separate the back component from the keyboard and screen, exposing the middle of the phone and keyboard pad. Next, separate the back component from the keyboard and screen, exposing the middle of the phone and keyboard pad.
  • Next, separate the back component from the keyboard and screen, exposing the middle of the phone and keyboard pad.
Agregar Comentario
Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard. Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard. Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard.
  • Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard.
Agregar Comentario
Conclusión
Katelynn Lee
Miembro Desde 18/10/11
1 Reputación
2 Guías creadas
Equipo
James Madison, Team 1-6, Allen Fall 2011 Miembro de James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 4,062
