Introducción
Make sure you look at the Samsung P241 Troubleshooting Guide first to see if you can solve your problem without taking the DVD player apart.
Partes
No se requieren partes.
You will need to be near a power source for this  guide. With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
  • You will need to be near a power source for this guide.
  • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
Agregar Comentario
Pull the top cover towards you until you can lift it up and off. Pull the top cover towards you until you can lift it up and off.
  • Pull the top cover towards you until you can lift it up and off.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 14-7, Forte Winter 2011 Miembro de Cal Poly, Team 14-7, Forte Winter 2011
CPSU-FORTE-W11S14G7
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 371
