Introducción
This guide will show you how to replace a faulty speaker.
Partes
No se requieren partes.
Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
  • Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
Agregar Comentario
Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
  • Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove six 5 mm Phillips #0 screws from the back of the phone.
  • Remove six 5 mm Phillips #0 screws from the back of the phone.
Agregar Comentario
Insert a plastic opening tool into the seam between the back case and the rest of the phone.
  • Insert a plastic opening tool into the seam between the back case and the rest of the phone.
  • Working along the seam, pry the back from the phone.
Agregar Comentario
Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out. Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
  • Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
Agregar Comentario
Conclusión
Morgan Yost
Miembro Desde 08/04/13
46 Reputación
12 Guías creadas
Equipo
Cal Poly, Team 17-1, Regan Spring 2013 Miembro de Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 137
