Introducción
Use this guide to replace the daughterboard in the Samsung Mythic SGH-a897.
Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
  • Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
Agregar Comentario
Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
  • Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
Agregar Comentario
Remove six 5 mm Phillips #0 screws from the back of the phone.
  • Remove six 5 mm Phillips #0 screws from the back of the phone.
Agregar Comentario
Insert a plastic opening tool into the seam between the back case and the rest of the phone.
  • Insert a plastic opening tool into the seam between the back case and the rest of the phone.
  • Working along the seam, pry the back from the phone.
Agregar Comentario
Use a plastic opening tool to disconnect the camera cable from the motherboard. Carefully remove the camera from the phone.
  • Use a plastic opening tool to disconnect the camera cable from the motherboard.
  • Carefully remove the camera from the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two remaining 3.75 mm Phillips screws.
  • Remove the two remaining 3.75 mm Phillips screws.
Agregar Comentario
Firmly grip the black lever with tweezers Use the tweezers to flip the black lever up so that it is perpendicular to the motherboard.
  • Firmly grip the black lever with tweezers
  • Use the tweezers to flip the black lever up so that it is perpendicular to the motherboard.
Agregar Comentario
Carefully use the tweezers to slide the black ZIF cable out of the socket.
  • Carefully use the tweezers to slide the black ZIF cable out of the socket.
Agregar Comentario
Use the tweezers to unclip the black connector as shown. Use the tweezers to unclip the black connector as shown.
  • Use the tweezers to unclip the black connector as shown.
Agregar Comentario
Use the tweezers to unclip the orange flexible circuit board from the side of the phone. Use the tweezers to unclip the orange flexible circuit board from the side of the phone.
  • Use the tweezers to unclip the orange flexible circuit board from the side of the phone.
Agregar Comentario
Use the tweezers to unclip the other orange, smaller flexible circuit board.
  • Use the tweezers to unclip the other orange, smaller flexible circuit board.
  • Work carefully. This is a very delicate part of the phone that can easily be broken.
Agregar Comentario
Slide one side of the tweezers underneath the red and blue wires of the capacitor. Carefully apply pressure away from the phone to lift.
  • Slide one side of the tweezers underneath the red and blue wires of the capacitor.
  • Carefully apply pressure away from the phone to lift.
Agregar Comentario
Carefully tilt the motherboard up from the back of the phone. Don't remove the motherboard completely. There is one more clip on the backside of the motherboard that needs to be removed.
  • Carefully tilt the motherboard up from the back of the phone.
  • Don't remove the motherboard completely. There is one more clip on the backside of the motherboard that needs to be removed.
  • Use tweezers to unclip the black connector.
Agregar Comentario
use the tweezers to unclip the connector as shown. This is the only attachment that is holding the daughterboard to the motherboard. You can no remove the daughterboard.
  • use the tweezers to unclip the connector as shown.
  • This is the only attachment that is holding the daughterboard to the motherboard. You can no remove the daughterboard.
Agregar Comentario
Conclusión
Collin Gordon
Miembro Desde 08/04/13
45 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-1, Regan Spring 2013 Miembro de Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 160
