Introducción
This guide will go over where to locate and replace the rear cooling fan. You will need to reference the Removing Samsung ML2510 Back Panel repair guide to complete this one.
Partes
No se requieren partes.
Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
  • Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
Agregar Comentario
Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2  screws on the back of the printer.
  • Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2 screws on the back of the printer.
Agregar Comentario
Gently lift the top panel while simultaneously pulling off the back panel. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  • Gently lift the top panel while simultaneously pulling off the back panel.
  • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
Agregar Comentario
Once the fan is detached, unplug the fan from the circuit board. Slide the fan's wiring through the anchored slit.
  • Once the fan is detached, unplug the fan from the circuit board.
  • Slide the fan's wiring through the anchored slit.
Agregar Comentario
With the new fan, thread the wiring through the old fan's slit.
  • With the new fan, thread the wiring through the old fan's slit.
  • Reconnect the fan by plugging it back into the circuit board.
  • Reattach the back panel following these instructions in reverse order.
Agregar Comentario
Linea de Meta
bbaustin
Miembro Desde 12/10/11
199 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-18, Regan Fall 2011 Miembro de Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Miembros
6 Guías creadas
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 2
Últimos 30 Días: 18
Todo El Tiempo: 2,745
