Saltar al contenido principal
Samsung Juke Camera/Speaker Replacement
Qué necesitas
  1. Samsung Juke Camera/Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke Camera/Speaker Replacement: paso 2, imagen 1 de 2 Samsung Juke Camera/Speaker Replacement: paso 2, imagen 2 de 2
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke Camera/Speaker Replacement, Camera/Speaker: paso 3, imagen 1 de 1
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke Camera/Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke Camera/Speaker Replacement: paso 5, imagen 1 de 3 Samsung Juke Camera/Speaker Replacement: paso 5, imagen 2 de 3 Samsung Juke Camera/Speaker Replacement: paso 5, imagen 3 de 3
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke Camera/Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke Camera/Speaker Replacement: paso 7, imagen 1 de 2 Samsung Juke Camera/Speaker Replacement: paso 7, imagen 2 de 2
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke Camera/Speaker Replacement: paso 8, imagen 1 de 2 Samsung Juke Camera/Speaker Replacement: paso 8, imagen 2 de 2
    • Use the iFixit opening tool to gently pry the camera/speaker off.
Conclusión
Una persona más ha completado esta guía.
Renee Kuzniar
Miembro Desde 04/13/10
82 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-18, Maness Spring 2010 Miembro de Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 3,492
