Introducción
Use this guide to replace the speaker.
Partes
No se requieren partes.
Slide the battery cover downwards with pressure focused on the center of the cover.
  • Slide the battery cover downwards with pressure focused on the center of the cover.
  • Lift the cover off of the phone.
Agregar Comentario
Grasp the bottom left and right corners of the battery and lift it from its housing.
  • Grasp the bottom left and right corners of the battery and lift it from its housing.
Agregar Comentario
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force. Insert the Plastic Opening Tool in between the front and rear cases. Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
  • Insert the Plastic Opening Tool in between the front and rear cases.
  • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
Agregar Comentario
Lift the rear case off of the phone.
  • Lift the rear case off of the phone.
Agregar Comentario
Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
  • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
  • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
Agregar Comentario
Use the spudger to detach the speaker ribbon cable. Use the spudger to detach the speaker ribbon cable.
  • Use the spudger to detach the speaker ribbon cable.
Agregar Comentario
Lift the speaker out of its compartment.
  • Lift the speaker out of its compartment.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Paul Piller
Miembro Desde 12/04/11
56 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 24-57, Amido Spring 2011 Miembro de Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 1,630
