Saltar al contenido principal
Samsung Jack Motherboard Replacement
Qué necesitas
  1. Samsung Jack Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Motherboard Replacement: paso 2, imagen 1 de 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Motherboard Replacement, Rear Case: paso 3, imagen 1 de 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Motherboard Replacement: paso 4, imagen 1 de 3 Samsung Jack Motherboard Replacement: paso 4, imagen 2 de 3 Samsung Jack Motherboard Replacement: paso 4, imagen 3 de 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Motherboard Replacement: paso 5, imagen 1 de 1
    • Lift the rear case off of the phone.
  6. Samsung Jack Motherboard Replacement, Speaker: paso 6, imagen 1 de 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  7. Samsung Jack Motherboard Replacement: paso 7, imagen 1 de 2 Samsung Jack Motherboard Replacement: paso 7, imagen 2 de 2
    • Use the spudger to detach the speaker ribbon cable.
  8. Samsung Jack Motherboard Replacement: paso 8, imagen 1 de 1
    • Lift the speaker out of its compartment.
  9. Samsung Jack Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
    • Remove the power and volume buttons on the right side of the Motherboard.
  10. Samsung Jack Motherboard Replacement: paso 10, imagen 1 de 2 Samsung Jack Motherboard Replacement: paso 10, imagen 2 de 2
    • Use a spudger to detach the camera ribbon cable.
    • Lift the camera off of the Motherboard.
  11. Samsung Jack Motherboard Replacement: paso 11, imagen 1 de 2 Samsung Jack Motherboard Replacement: paso 11, imagen 2 de 2
    • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
  12. Samsung Jack Motherboard Replacement: paso 12, imagen 1 de 3 Samsung Jack Motherboard Replacement: paso 12, imagen 2 de 3 Samsung Jack Motherboard Replacement: paso 12, imagen 3 de 3
    • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
    • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
  13. Samsung Jack Motherboard Replacement: paso 13, imagen 1 de 2 Samsung Jack Motherboard Replacement: paso 13, imagen 2 de 2
    • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
    • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • Use a spudger to disconnect the Motherboard ribbon cable.
  14. Samsung Jack Motherboard Replacement: paso 14, imagen 1 de 1
    • Lift the Motherboard off of the phone.
Conclusión
Jaime Serrano
Miembro Desde 04/11/11
59 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 24-57, Amido Spring 2011 Miembro de Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,143
