Introducción
Use this guide to remove the old keyboard and install a new one.
Slide the battery cover downwards with pressure focused on the center of the cover.
  • Slide the battery cover downwards with pressure focused on the center of the cover.
  • Lift the cover off of the phone.
Agregar Comentario
Grasp the bottom left and right corners of the battery and lift it from its housing.
  • Grasp the bottom left and right corners of the battery and lift it from its housing.
Agregar Comentario
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
Agregar Comentario
The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force. Insert the Plastic Opening Tool in between the front and rear cases. Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
  • Insert the Plastic Opening Tool in between the front and rear cases.
  • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
Agregar Comentario
Lift the rear case off of the phone.
  • Lift the rear case off of the phone.
Agregar Comentario
Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
Agregar Comentario
There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet. Use a spudger to remove the wire connector under the antenna. Use a spudger to remove the wire connector under the antenna.
  • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
  • Use a spudger to remove the wire connector under the antenna.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
  • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
  • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
Agregar Comentario
Use the spudger to detach the speaker ribbon cable. Use the spudger to detach the speaker ribbon cable.
  • Use the spudger to detach the speaker ribbon cable.
Agregar Comentario
Lift the speaker out of its compartment.
  • Lift the speaker out of its compartment.
Agregar Comentario
Remove the power and volume buttons on the right side of the Motherboard.
  • Remove the power and volume buttons on the right side of the Motherboard.
Agregar Comentario
Use a spudger to detach the camera ribbon cable. Lift the camera off of the Motherboard.
  • Use a spudger to detach the camera ribbon cable.
  • Lift the camera off of the Motherboard.
Agregar Comentario
Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard. Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
  • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
Agregar Comentario
Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard. Use a spudger to carefully pull the ribbon cables away from the ZIF connectors. Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
  • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
  • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
Agregar Comentario
There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet. Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
  • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
  • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
  • Use a spudger to disconnect the Motherboard ribbon cable.
Agregar Comentario
Lift the Motherboard off of the phone.
  • Lift the Motherboard off of the phone.
Agregar Comentario
The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force. Insert the Plastic Opening Tool between the LCD frame and the front case of the phone. Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
  • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
  • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
  • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
Agregar Comentario
Lift up the LCD frame. Lift up the LCD frame.
  • Lift up the LCD frame.
Agregar Comentario
The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard. The keyboard and directional keys are glued separately to the LCD frame. Insert the spudger between the keyboard and the frame.
  • The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard.
  • The keyboard and directional keys are glued separately to the LCD frame.
  • Insert the spudger between the keyboard and the frame.
  • Peel the keyboard off by sliding the spudger back and forth across the LCD frame.
Agregar Comentario
Insert the spudger between the directional keys and the frame. Peel the directional keys off by sliding the spudger back and forth across the LCD frame. Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
  • Insert the spudger between the directional keys and the frame.
  • Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jaime Serrano
Miembro Desde 11/04/11
59 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 24-57, Amido Spring 2011 Miembro de Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,971
